THOMAS'S WEB SITE
Date:  5-18-2016
Number of Hours:  6.00
Brief Description:  Construction of Canopy Frame
Today I bent the second almost identical bow. I had to correct the curvature a little bit, also on the bow from yesterday. After I took it out of the clamp position, there was still too much tension which wouldn't keep the tube in place. I used also a tube clamped with the vice to do some minor adjustments. At the end, I cut and sanded the lower tube pieces so it would be shaped in a 20° angle.
